Re: anyone with details or info on these ??
rock ...... don't ever recall seeing one of these in Vic other than datnats and at goulburn in '05 ????
very nice spec and options that they had :
Engine Specs - Series I (1996 - July 1998). This is for the 25t RS-Four, as the most commonly seen version here in Australia:
* RB25DET engine, 2.5 litres, DOHC, 24-valve, turbocharged, same basic specs as a series II R-33 Skyline GTS25t;
* 173kW @ 6400rpm, 275Nm @ 4800rpm - figures quoted are at the flywheel;
* E-AT Electronically-controlled four-speed automatic with overdrive and electronic lock-up torque converter;
* ATESSA-ETS electronically-controlled four wheel drive... There was no manual option in the Series I.
Engine Specs - Series II (August 1998 - 2001). Once again, this is for the 25t RS-Four.
* RB25DET Neo engine, 2.5 litres, DOHC, 24-valve, turbocharged, same basic specs as an R-34 Skyline GTt;
* 206kW @ 6400rpm, 333Nm @ 3200rpm (or 343Nm @ 3200rpm in RS-Four S manual) - figures quoted are at the flywheel;
* E-ATx Electronically-controlled four-speed automatic with overdrive and electronic lock-up torque converter; or
* M-ATx E-AT Electronically-controlled four-speed automatic with overdrive and electronic lock-up torque converter and Tiptronic function; or
* 5-speed manual
FACTORY FEATURES AND OPTIONS
All Stageas have:
* Power windows;
* Power mirrors (including a fold-in feature for parking in tight spaces);
* Driver's and Passenger's SRS airbags;
* Roof rails;
* Reclinable and fold-down (by use of a nifty handle in the luggage bay) rear seats, with a centre fold-down arm rest;
* Climate control air-conditioning;
* Electronic odometer and dual trip-meters;
* Various hooks and tie-down points in the luggage bay so your cargo doesn't go flying around;
* Tilt-adjustable steering column;
* 12v lighter socket in the rear luggage area;
* Leather steering wheel;
* Front fog lamps;
* Front, variable intermittent windscreen wipers;
* Rear window wiper;
* Front spoiler;
* UV-cutting glass (front doors and windscreen) - all models;
* Dual cup-holders in the dashboard;
* Keyless entry;
Commonly fitted Optional Extras include:
* Front centre arm rest, some of which can be opened towards either the driver or passenger;
* Luggage bay roll-out cover;
* Luggage bay safety net;
* Privacy glass (rear doors and rear luggage area) - RS models and above;
* Dual sunrooves (front one is tilt and slide, rear is a slide-only);
* Electric, self-closing rear door (boot)...
Other, less common Stagea Optional Extras include:
* Leather seats and interior trims;
* Electric seats (only available with the leather option)...
* Extra 12v bayonet-style sockets on the left side of the luggage area, the inside of the luggage area door and the D-pillar for bayonet-fit accessories such as a torch, etc.;
* Limited Slip Differential (manual RS Four S models)
CHASSIS CODES
Model:......................Driveline:...............Engine:..............Chassi
s Code:
RS Four S..................AWD manual..........RB25DET Neo......WGNC34
RS Four V..................AWD......................RB25DET............WGNC34
RS Four.....................AWD......................RB25DET............WGNC34
RS............................RWD......................RB25DET............WGC34
25X Four...................AWD.......................RB25DE.............WGNC34
25G Four...................AWD.......................RB25DE.............WGNC34
25X..........................RWD.......................RB25DE.............WGC34
25G..........................RWD.......................RB25DE.............WGC34
20G..........................RWD.......................RB20DE.............WHC34
all too late now ... looked at different options in wagons for around 4mnths before settling on the Foz in the middle of last year .........
Posted on: 2007/4/27 8:17
Subject Poster Date
     anyone with details or info on these ?? boofhead 2007/4/27 7:52
       Re: anyone with details or info on these ?? pepper 2007/4/27 8:04
         Re: anyone with details or info on these ?? boofhead 2007/4/27 8:07
           Re: anyone with details or info on these ?? pepper 2007/4/27 8:09
           Re: anyone with details or info on these ?? wardat 2007/4/27 8:11
           Re: anyone with details or info on these ?? dattodude 2007/4/27 8:11
             Re: anyone with details or info on these ?? boofhead 2007/4/27 8:17
               Re: anyone with details or info on these ?? Anonymous 2007/4/27 9:26
                 Re: anyone with details or info on these ?? matbighat 2007/4/27 11:31
                   Re: anyone with details or info on these ?? flydato 2007/4/29 8:48
                     Re: anyone with details or info on these ?? Anonymous 2007/4/30 5:31
