a15 turbo motor for sale
From campbelltown (sydney) australia
hey guys again i want to advertise my a15 a basic run down the whole engine was rebuilt top tp bottom, with brand new oil pump and water pump bottom up: fully balanced front pulley to clutch plate. a14 block a15 internals,low comp std pistons with chrome top ring,steel headgasket same as speedway racecar, arp headstud kit ported gx head oversized stainless steel valves inlet and exhaust, double valve springs, turbo grind cam profile. also the block has been modified by having radiator hose shortened with an adapter to use modern day radiator hoses the bigger ones the radiator elbow also has a ca18 det water temp sensor mounted in a machined boss. all work except for the custom machine work was all done by Jeff Taylor the motor hasnt run yet but its all been cvered in clevite bearing lubricant so isnt rusty at all.
secondly hanging off the side its a t25 off a ca18det no shaft play other than normal clearances, custom exhaust manifold with external wastegate street gate 38 turbosmart with 2.5 inch dump pipe.
on the other side is a half built injection manifold has all injectors mounted with custom billet fuel rail ca18det throttle body, ca18det oxygen sensor sard fuel pressure regulatorits been made using weber maifold and a fair bit of machine work.
i couldnt put a price on it but i wanna get rid of it and will sell it to the bidder that comes up with a price im happy with so if someone wants to bid 1000 bucks then you wont even get a reply to ur pm except to call u an idiot for wasting my time. thanks guys i hope to hear from someoen soon, this engine cost me over 6 grand to build and i will sell it for half that i would just really like to see it running one day as i think its performane will eclipse my ca18det if finished properly .
Posted on: 2007/5/1 3:35
* caution, sunglasses must be worn to view my ca18det *
Subject Poster Date
     a15 turbo motor for sale kegs 2007/5/1 3:35
       Re: a15 turbo motor for sale kegs 2007/5/3 2:54
         Re: a15 turbo motor for sale ca18det_man 2007/5/3 3:28
           Re: a15 turbo motor for sale kegs 2007/7/22 9:30
             Re: a15 turbo motor for sale picko 2007/7/22 9:40
               Re: a15 turbo motor for sale kegs 2007/7/22 9:45
                 Re: a15 turbo motor for sale reuby_tuesday 2007/7/22 10:15
                   Re: a15 turbo motor for sale picko 2007/7/22 10:53
                     Re: a15 turbo motor for sale reuby_tuesday 2007/7/22 10:55
                       Re: a15 turbo motor for sale Daveman 2007/7/22 14:43
                         Re: a15 turbo motor for sale Ronald 2007/7/27 6:10
                           Re: a15 turbo motor for sale reuby_tuesday 2007/8/3 8:53
