Re: what ecu do i use
From Newscastle, Australia
its up to the tuner and intended application really....
microtech are great for huge fuel dumps like in a rotary, but for more precise especially high boost turbo applications you will need an ECU with many fuel mapping points which can be set properly by the tuner. Its a black art really and to find someone good will be expensive. My tuner swears by Autronic over and above Motecs even...so that what I went with.
Posted on: 2007/5/30 19:11
Dont die wondering.....
Subject Poster Date
     what ecu do i use SLUG1200 2007/5/30 11:31
       Re: what ecu do i use dattodude 2007/5/30 13:29
         Re: what ecu do i use sunny 2007/5/30 13:48
           Re: what ecu do i use who_your_datty_1200 2007/5/30 14:03
           Re: what ecu do i use dattodude 2007/5/30 14:43
           Re: what ecu do i use converted 2007/5/30 19:11
             Re: what ecu do i use short-coupe 2007/5/30 23:37
               Re: what ecu do i use WARDY 2007/5/30 23:44
                 Re: what ecu do i use Whorida 2007/5/31 0:30
                   Re: what ecu do i use BUNDY351 2007/5/31 3:41
                     Re: what ecu do i use short-coupe 2007/5/31 3:45
         Re: what ecu do i use SLUG1200 2007/5/30 23:31
