Re: Where to put thermo fan activation sensor?
From Coondle, WA Australia
hmmm using a manual switch for your thermo seems fraught with danger. I have done it once to limp home my old 4wd, but I wouldnt reccommend it for daily use. You get distracted once and it could be too late for the ole a series.....
When I fitted the thermo to my patrol, the fitting kit came with a rubber shim that you put between the inlet pipe on the radiator and the hose. The sensor sat between the two like a sandwich. No screws in pipes. simple really.
Since I gather that yours has a threaded sensor, you either have to go down the custom pipe road like you spoke about, or tap into the top tank on the radiator. This will achieve the same effect as in the top hose.
about the time to turn it on, well I just did mine be trial and error. I had it turn on early, tried that, and just adjusted till i was happy with it and it never failed, the thermo setup that is. the rest of the car.... well its history now thank god.
Posted on: 2007/6/6 11:14
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
Subject Poster Date
     Where to put thermo fan activation sensor? 1200GXman 2007/6/6 7:37
       Re: Where to put thermo fan activation sensor? dat141 2007/6/6 7:55
         Re: Where to put thermo fan activation sensor? 1200GXman 2007/6/6 8:00
           Re: Where to put thermo fan activation sensor? Velociti 2007/6/6 8:05
           Re: Where to put thermo fan activation sensor? dat141 2007/6/6 8:06
             Re: Where to put thermo fan activation sensor? d1t 2007/6/6 8:11
               Re: Where to put thermo fan activation sensor? 1200GXman 2007/6/6 8:30
                 Re: Where to put thermo fan activation sensor? 1200GXman 2007/6/6 10:34
                   Re: Where to put thermo fan activation sensor? 1200GXman 2007/6/6 10:44
                     Re: Where to put thermo fan activation sensor? reuby_tuesday 2007/6/6 11:14
                       Re: Where to put thermo fan activation sensor? 1200GXman 2007/6/6 13:06
                         Re: Where to put thermo fan activation sensor? beattie 2007/6/6 13:18
                           Re: Where to put thermo fan activation sensor? B210sleeper 2007/6/6 21:20
                             Re: Where to put thermo fan activation sensor? Gary_P 2007/6/6 22:14
                               Re: Where to put thermo fan activation sensor? B210sleeper 2007/6/6 23:02
                                 Re: Where to put thermo fan activation sensor? Graemes50 2007/6/8 3:07
                                   Re: Where to put thermo fan activation sensor? 1200GXman 2007/6/8 5:36
                                     Re: Where to put thermo fan activation sensor? Cable_Tie 2007/6/8 7:51
