200SX rear disks bolt on
From Portland, OR, USA
I just took some measurements, and it appears that the disk brakes on the back of the 200SX bolt-on to the H150 diff from the B210. The 200SX has an H165 or H190 (not sure which) so the axle is different. The bearing and retainer are identical to the H150, and the bolt pattern appears to match. This could be a bolt-on conversion. Anyone tried it?
One remaining problem is the master cylinder, need a much larger one for these big bore calipers.
Posted on: 2007/7/2 7:18
Subject Poster Date
     200SX rear disks bolt on Blats 2007/7/2 7:18
       Re: 200SX rear disks bolt on leosnake_2000 2007/7/2 8:35
         Re: 200SX rear disks bolt on PIGDOG 2007/7/2 10:03
           Re: 200SX rear disks bolt on A14force 2007/7/3 5:14
             Re: 200SX rear disks bolt on Blats 2007/7/3 22:26
