Re: CA18DET Vacuum lines - which do I need?
From Canberra
Its not from the Workshop manual its part of the IPB (intergrated Parts Breakdown).
These numbers would be the ones nissan uses to order spare parts with.
It's the best diagram ive found to explain the vacumm system for the 8 port JDM heads.
My understanding is that by default the ports are open, these close when the engine is not making boost (ie Vacumm from the manifold). Therefore as long as you have pluged the lines and run a vacumm line to the Fuel pressure regulator you won't notice high RPM power loss but theoretically you will loose torque at low load/RPM.
Posted on: 2007/7/8 3:31
Subject Poster Date
     CA18DET Vacuum lines - which do I need? Mildman 2007/7/7 6:46
       Re: CA18DET Vacuum lines - which do I need? phat_dat1200 2007/7/7 7:19
         Re: CA18DET Vacuum lines - which do I need? mcgee 2007/7/7 8:06
           Re: CA18DET Vacuum lines - which do I need? sooty_grunter 2007/7/7 8:55
           Re: CA18DET Vacuum lines - which do I need? Mildman 2007/7/7 13:55
             Re: CA18DET Vacuum lines - which do I need? mcgee 2007/7/8 3:31
               Re: CA18DET Vacuum lines - which do I need? Daveman 2007/7/8 3:43
                 Re: CA18DET Vacuum lines - which do I need? perthute 2007/7/8 23:59
