Re: Vl turbo calipers on 200b strut??
From Geelong, Vic
vl turbo calipers bolt onto 200b struts? you sure about that one
unless they have a different bolt spacing to all the other commodore calipers, they wont work
they do work with 180b, sunny, early stanza and early 240k struts, as they have an 80mm bolt spacing
where as 200b has 88.9mm spacing, so do the hilux calipers
also the caliper mounts on the 200b struts are different offset to 180b, so the VL calipers would have to have this different offset also....which would be different to all other comodores aswell
Posted on: 2007/7/16 2:19
Subject Poster Date
     Vl turbo calipers on 200b strut?? CA120Y 2007/7/15 8:59
       Re: Vl turbo calipers on 200b strut?? TnPshow 2007/7/15 9:02
         Re: Vl turbo calipers on 200b strut?? PIGDOG 2007/7/16 2:19
           Re: Vl turbo calipers on 200b strut?? BigD 2007/7/16 8:09
             Re: Vl turbo calipers on 200b strut?? PIGDOG 2007/7/16 13:20
               Re: Vl turbo calipers on 200b strut?? BigD 2007/7/16 23:31
                 Re: Vl turbo calipers on 200b strut?? PIGDOG 2007/7/17 3:54
           Re: Vl turbo calipers on 200b strut?? TnPshow 2007/7/17 6:36
