Re: rear sway bar.
From Canberra
datsun_guy the grille on my 120Y is just a late model one, pretty common.
I have the front of my 120Y sitting on low king springs and stadard replacement 180B shocks I believe. The rear is standard height with some commodore shocks. 20mm front swaybar. When going into corners I can turn the wheel and the car just ploughs foreward until it loses enough speed then turns the corner. I'm running about 2-2.5deg neg camber but it stll scrubs the hell out of the outside edges of the tyres.
Can this be fixed by changing components or am I just going too hard into corners? I believe the rear "roll centre?" may be too high causing the understeer? The rear is damn high when braking into a corner... heres a pic:
Posted on: 2007/7/18 5:44
Subject Poster Date
     rear sway bar. datsun_guy 2007/7/17 14:35
       Re: rear sway bar. L18_B110 2007/7/17 23:29
         Re: rear sway bar. teretonga 2007/7/17 23:33
           Re: rear sway bar. sundat1200 2007/7/17 23:35
             Re: rear sway bar. L18_B110 2007/7/17 23:40
               Re: rear sway bar. Tyrie 2007/7/17 23:53
                 Re: rear sway bar. L18_B110 2007/7/18 0:16
                   Re: rear sway bar. datsun_guy 2007/7/18 3:00
                     Re: rear sway bar. 1000Coupe 2007/7/18 3:37
                       Re: rear sway bar. datsun_guy 2007/7/18 3:44
                         Re: rear sway bar. sidedraught 2007/7/18 3:54
                           Re: rear sway bar. L18_B110 2007/7/18 4:02
                             Re: rear sway bar. sidedraught 2007/7/18 4:05
                               Re: rear sway bar. Tyrie 2007/7/18 5:44
                                 Re: rear sway bar. PIGDOG 2007/7/18 5:51
                                   Re: rear sway bar. Tyrie 2007/7/18 6:06
                                   Re: rear sway bar. benny 2007/7/18 6:10
                                     Re: rear sway bar. benny 2007/7/18 6:11
                                       Re: rear sway bar. Tyrie 2007/7/18 6:15
                                     Re: rear sway bar. PIGDOG 2007/7/18 6:12
                                       Re: rear sway bar. benny 2007/7/18 6:18
                                         Re: rear sway bar. Tyrie 2007/7/18 6:22
                                         Re: rear sway bar. benny 2007/7/18 6:23
                                           Re: rear sway bar. Tyrie 2007/7/18 6:32
                                             Re: rear sway bar. benny 2007/7/18 6:45
                                               Re: rear sway bar. Rallytwit 2007/7/18 15:40
                                                 Re: rear sway bar. LittleFireyOne 2007/7/18 21:52
                                                   Re: rear sway bar. datsun_guy 2007/7/18 23:23
                                                     Re: rear sway bar. Rallytwit 2007/7/19 17:39
                                                       Re: rear sway bar. datsun_guy 2007/7/20 1:08
                                                         Re: rear sway bar. Rallytwit 2007/7/20 14:39
                     Re: rear sway bar. L18_B110 2007/7/18 3:50
