Re: removing battery tray
From Brisbane, Australia
Use a spot weld drill:
1. Centre Punch and Spotweld Drill
2. Drill through the first layer
3. Remove first Layer
The spot weld drill is basically a flat cutter with a tiny centre drill.
It can be hard to access all of the spotwelds for the battery tray. You may need a combination of drilling and cutting.
Posted on: 2007/8/11 13:47
Subject Poster Date
     removing battery tray appsy1 2007/8/11 13:22
       Re: removing battery tray phunkdoktaspok 2007/8/11 13:33
         Re: removing battery tray crzy_1200_ute 2007/8/11 13:40
           Re: removing battery tray Cable_Tie 2007/8/11 13:47
             Re: removing battery tray mikgan 2007/8/11 13:49
               Re: removing battery tray sidedraught 2007/8/11 14:22
                 Re: removing battery tray PIGDOG 2007/8/11 22:36
                   Re: removing battery tray mikgan 2007/8/12 8:38
                     Re: removing battery tray BUNDY351 2007/8/12 9:53
                       Re: removing battery tray 1200rallycar 2007/8/12 13:52
                         Re: removing battery tray PIGDOG 2007/8/12 14:00
