piston HELP!!
Not too shy to talk
From Cape Town
Wondering if you guys could help out with a piston swap and specs that somebody has done for an A12 Block?? Please note i am running an A14GX head and a 264 cam with Su's!!?!
Finally converted my ignition to electronic with a part from pertronix, makes a huge difference, plus this unit is quite simple, it fits inside any standard distrubutor and there is only 2 wires and they connect straight on 2 the positve and negative of the coil and then you cut the ballast out, wonderful part, i highly recommend it!!!
Posted on: 2007/8/26 13:57
Subject Poster Date
     piston HELP!! tom1200 2007/8/26 13:57
