Anyone using a Sunny master cylinder with rear discs?
From brisbane
I would like to fit a 13/16" Sunny brake master cylinder to my 1200. I know when I fitted the front and rear discs previously I needed to remove the residual pressure valves from both lines out of the 1200 master cylinder.
I am assuming that the Sunny master cylinder will have one in the rear line.
If you have this set up on your car did you remove the residual pressure valve? What difference did it make?
Thanks Matty
Posted on: 2007/9/24 21:06
1985 CA18DET Datsun 1200 ute
1969 A12 Datsun 1000 coupe
Subject Poster Date
     Anyone using a Sunny master cylinder with rear discs? matty 2007/9/24 21:06
       Re: Anyone using a Sunny master cylinder with rear discs? PIGDOG 2007/9/24 23:40
