Re: What's that buzzing sound........?
From Cape Town ZA
Cable_Tie wrote:
Can you wire another spring alongside temporarily to take up the slop? A bit of chewy even to pinpoint the cause?
Reading your suggestion, I can see where your handle comes from...
Coops, I have an external waste gate, sometimes it would also start barking and buzzing, the car would then jerk and choke when that happened, although that was right near the end. Eventually I found out that the gate's valve had come loose from the actuator and it's membrane. Tightening up the little grub screws fixed the problem. Just a thought that the little flap/valve might be worked loose from it's shaft, that's if the other suggestions don't serve up anything...
Posted on: 2007/11/26 6:58
1200 GX Sedan
New(being installed)
4AGE 20V NA
Old
4AGZE 16V turbo
196.5KW/283NM
800m - 200km/h
400m - 12.3s
Subject Poster Date
     What's that buzzing sound........? Coops 2007/11/25 21:58
       Re: What's that buzzing sound........? Cable_Tie 2007/11/26 0:32
         Re: What's that buzzing sound........? Coops 2007/11/26 2:49
           Re: What's that buzzing sound........? tappet 2007/11/26 6:35
             Re: What's that buzzing sound........? Coops 2007/11/27 2:59
               Re: What's that buzzing sound........? kegs 2007/11/27 6:08
         Re: What's that buzzing sound........? kululadotgroen 2007/11/26 6:58
