Re: Gearbox oil for FWD car. What must I use GL4 or GL5?
From South Africa, Bloemfontein
Some more info I got from the internet.This is a quote of someone's reply about the differences between the oils.
GL-5 gear oils are for gears like our differentials where the pinion is below the centerline of the ring gear. You can look at the outside of the differential housing on the front side and see that. There is much sliding on the gear teeth, and the oil has to be blended for that. These are called hypoid gears. A gearbox without hypoid gears, like a transmission, does not need this particular additive package in the oil. GL-4 gear oil works well. Some GL-5 oils used a sulfur based additive to make them GL-5, and the sulfur would damage yellow metals...brass, bronze, & copper...in the transmission. Many modern GL-5 gear oils do not have the sulfur in them and are labeled for both GL-4 and GL-5 applications.
Posted on: 2008/2/6 8:01
1977 Datsun 1200GX
Subject Poster Date
     Gearbox oil for FWD car. What must I use GL4 or GL5? 1200GXman 2008/2/6 7:21
       Re: Gearbox oil for FWD car. What must I use GL4 or GL5? beattie 2008/2/6 7:46
         Re: Gearbox oil for FWD car. What must I use GL4 or GL5? 1200GXman 2008/2/6 7:55
           Re: Gearbox oil for FWD car. What must I use GL4 or GL5? 1200GXman 2008/2/6 8:01
       Re: Gearbox oil for FWD car. What must I use GL4 or GL5? DJF280 2008/2/6 12:57
         Re: Gearbox oil for FWD car. What must I use GL4 or GL5? beattie 2008/2/6 22:16
