Re: Hitachi (SU's) Where to start? Baseline/ drilling water ports
You do not need to use the water passages, but in a cold area it might be a good idea. No idea about drilling the head though. Or you could use a hot-air intake for winter time to prevent carb-icing.
Start with either 20-weight oil, or ATF. Nissan recommended 20W or 10W30 Elephant Oil, but any brand of motor oil will work. Others have reported success with ATF (automatic transmission fluid), sewing machine oil (generally 10W), or motorcyle oil. The lighter oils tend to run the carb on the lean side.
More details: club wiki
Posted on: 2008/2/13 7:50
Subject Poster Date
     Hitachi (SU's) Where to start? Baseline/ drilling water ports Bluemax 2008/2/13 7:40
       Re: Hitachi (SU's) Where to start? Baseline/ drilling water ports ddgonzal 2008/2/13 7:50
         Re: Hitachi (SU's) Where to start? Baseline/ drilling water ports WhiteSedan 2008/2/13 8:04
           Re: Hitachi (SU's) Where to start? Baseline/ drilling water ports Bluemax 2008/2/13 8:10
             Re: Hitachi (SU's) Where to start? Baseline/ drilling water ports Anonymous 2008/2/13 8:57
               Re: Hitachi (SU's) Where to start? Baseline/ drilling water ports WhiteSedan 2008/2/13 9:05
                 Re: Hitachi (SU's) Where to start? Baseline/ drilling water ports Anonymous 2008/2/13 9:09
                   Re: Hitachi (SU's) Where to start? Baseline/ drilling water ports tom1200 2008/2/13 22:03
                     Re: Hitachi (SU's) Where to start? Baseline/ drilling water ports tom1200 2008/2/13 22:09
