Re: CA18 gearbox's....?
Quite a regular
From orange nsw
Yep you should be able to get it to fit in there nicely and the gearstick coming out of the original hole is a bonus. its a bit too far back with a ca gearbox.
The front of the trans tunnel may need a slight massage to clear a few bits on the bellhousing. i mounted my engine close to the firewall but if you move it forward a bit it may not need this.
Also the ca turbo gears will fit into the stumpy case, just have to run the stumpy output shaft. Makes it a bit stronger cause i have heard that the stumpys are a bit weak.
Also may have to drill a hole in the side of the trans tunnel to fill the geargox up with oil or just fill it before you install it.
Posted on: 2008/3/18 19:15
Subject Poster Date
     CA18 gearbox's....? datspeed 2008/3/17 10:01
       Re: CA18 gearbox's....? whoridas_girl 2008/3/17 10:21
       Re: CA18 gearbox's....? old_school 2008/3/17 10:23
         Re: CA18 gearbox's....? datspeed 2008/3/18 9:53
           Re: CA18 gearbox's....? datb110 2008/3/18 19:15
             Re: CA18 gearbox's....? Lachie 2008/3/18 22:29
