Re: A15 Clutches
From Southern Highlands, NSW, Australia
In my racecar i'm using a PBR rpm pressure plate (the yellow ones), which is their heavy duty model or something. When I was running the 60 series I used a standard clutch plate that I prised off a rusty old engine out in the paddock with a screwdriver, it worked a treat and didn't slip in one and a half seasons of supersprints/hillclimbs. Now i'm using an organic sprung center exedy item with the same pressure plate for the toyota gearbox and it's holding up quite well.
Posted on: 2008/3/18 8:46
'72 1200 sedan hillclimb/supersprint car
Subject Poster Date
     A15 Clutches nismo 2008/3/17 10:22
       Re: A15 Clutches Freak 2008/3/17 11:00
         Re: A15 Clutches reuby_tuesday 2008/3/17 14:32
       Re: A15 Clutches ddgonzal 2008/3/17 18:13
         Re: A15 Clutches nismo 2008/3/17 21:15
           Re: A15 Clutches Dodgeman 2008/3/17 23:31
             Re: A15 Clutches ddgonzal 2008/3/18 0:19
               Re: A15 Clutches Bajan_B310 2008/3/20 22:36
           Re: A15 Clutches woody 2008/3/18 8:20
             Re: A15 Clutches dat141 2008/3/18 8:46
             Re: A15 Clutches A14force 2008/3/18 8:47
               Re: A15 Clutches nismo 2008/3/18 9:35
               Re: A15 Clutches reuby_tuesday 2008/3/18 9:44
                 Re: A15 Clutches A14force 2008/3/20 6:16
                   Re: A15 Clutches dattoman_1000 2008/3/20 16:01
         Re: A15 Clutches Cable_Tie 2008/3/17 21:16
