Browsing this Thread:
1 Anonymous Users
Re: Wideband O |
From San Diego, CA
I also have the hand held unit but the programing should be the same. Try going into LM Programer. There should be a sensitivity adjustment for the 0-5volt and 0-2volt output. Your guage should be using the 0-5volt. Turn it down to to the minimum update rate. You dont want it updating to fast unless you are loging. Also sounds like you may be overheating the sensor (high EGTs). Its very important to have the sensor way down stream or you will overheat it and the readings will be all over the place. And what bones said is right. If you have any leaks in your exhaust the extra oxygen will throw the reading off as full lean.
Posted on: 2008/3/25 3:10
