Re: Struts? What can be done?
From Mandurah, Western Australia
Check under Wiki on the main menu.
Stanza setup has been debated on here before and it is what I run, plus I feel the larger stub axle is better for brake upgrade options.
Stanza struts will bolt straight in with the stanza lower control arms. On the support rod (use 1200) you need to grind it out slightly to clear one of the bolts on the lower control arm where the ball joint bolts on. Use the standard steering arms and it all fits.
Adjustable camber tops would be an advantage and this is my next step and should give you about a 3 degree adjustment. But will almost correct the camber issue.
Posted on: 2008/5/3 13:58
Subject Poster Date
     Struts? What can be done? datspeed 2008/5/3 13:08
       Re: Struts? What can be done? datto1000wagon 2008/5/3 13:16
         Re: Struts? What can be done? datspeed 2008/5/3 13:22
           Re: Struts? What can be done? old_school 2008/5/3 13:58
             Re: Struts? What can be done? Anonymous 2008/5/3 15:02
               Re: Struts? What can be done? perthute 2008/5/4 2:52
                 Re: Struts? What can be done? ROConnor 2008/5/4 3:00
                   Re: Struts? What can be done? ROConnor 2008/5/4 3:04
                     Re: Struts? What can be done? datspeed 2008/5/4 3:47
                       Re: Struts? What can be done? wolki101 2008/5/4 8:09
                         Re: Struts? What can be done? hotrocket 2008/5/4 8:30
                           Re: Struts? What can be done? wolki101 2008/5/4 8:33
                             Re: Struts? What can be done? hotrocket 2008/5/4 8:37
                               Re: Struts? What can be done? wolki101 2008/5/4 8:54
                                 Re: Struts? What can be done? revhead001 2008/5/4 9:07
                                 Re: Struts? What can be done? phunkdoktaspok 2008/5/4 9:36
                                   Re: Struts? What can be done? datspeed 2008/5/4 11:19
                                     Re: Struts? What can be done? Anonymous 2008/5/4 11:20
                                       Re: Struts? What can be done? hotrocket 2008/5/4 11:51
                                         Re: Struts? What can be done? SAnt0s 2008/5/8 8:38
                                           Re: Struts? What can be done? PIGDOG 2008/5/8 9:54
                                     Re: Struts? What can be done? hotrocket 2008/5/4 11:50
                       Re: Struts? What can be done? hotrocket 2008/5/4 8:18
       Re: Struts? What can be done? hotrocket 2008/5/4 8:51
       Re: Struts? What can be done? blob 2008/5/9 7:16
         Re: Struts? What can be done? WhiteSedan 2008/5/9 7:21
           Re: Struts? What can be done? blob 2008/5/9 7:48
             Re: Struts? What can be done? PIGDOG 2008/5/9 8:05
               Re: Struts? What can be done? WhiteSedan 2008/5/9 8:31
                 Re: Struts? What can be done? blob 2008/5/9 8:35
                   Re: Struts? What can be done? PIGDOG 2008/5/9 10:16
