1200 coupe race suspension setup?
From New Zealand
Hi would anyone be able to help with a couple of prob's i am now having.
1. I am pushing the car hard then braking into a hair pin and the back starts bouncing as i brake and down change.
2. The back of the car is bouncing on hard cornering, could be to hard in the back spring area maybe?.
3. Am understeering like you would not believe.
Car has bluebird front end, 4degrees caster, a small amount of toe out and 2 degrees of camber. I am running 185 kumho slicks, ute rear end, gas shocks and reversed springs(4)
any help appreciated
Posted on: 2008/5/7 3:11
Subject Poster Date
     1200 coupe race suspension setup? jared 2008/5/7 3:11
       Re: 1200 coupe race suspension setup? sikyne 2008/5/7 3:53
         Re: 1200 coupe race suspension setup? sikyne 2008/5/7 4:02
         Re: 1200 coupe race suspension setup? jared 2008/5/7 4:32
           Re: 1200 coupe race suspension setup? L18_B110 2008/5/7 4:50
             Re: 1200 coupe race suspension setup? bert 2008/5/7 6:35
               Re: 1200 coupe race suspension setup? bobthebuilder 2008/5/7 10:56
                 Re: 1200 coupe race suspension setup? sikyne 2008/5/7 23:25
                   Re: 1200 coupe race suspension setup? Rallytwit 2008/5/8 7:36
       Re: 1200 coupe race suspension setup? L18_B110 2008/5/7 3:57
       Re: 1200 coupe race suspension setup? Rallytwit 2008/5/7 4:40
