Re: 4 cyl torana pistons into a14/a15
Couple of problems.
The stock bore of an A14/15 is 76mm & 79mm is generally regarded as the maximum overbore size.
The wrist pin hole in the shorter A12 rod is for the 17.5mm pin. The longer A14/15 rod pin hole was 19mm.
The A12A & short deck A13 used the shorter A12 length rod, but with the larger 19mm pin hole.
This does not look like a workable combination by the looks of it.
Posted on: 2008/5/27 17:20
Love your Datsun.
Treat it well.
Subject Poster Date
     4 cyl torana pistons into a14/a15 datto1000wagon 2008/5/27 12:59
       Re: 4 cyl torana pistons into a14/a15 Dodgeman 2008/5/27 17:20
         Re: 4 cyl torana pistons into a14/a15 datto1000wagon 2008/5/27 21:42
