Re: ca18 in to coupe
From newcastle, NSW
You can use the standard tranny tunnel with a CA18DET conversion, all i did when i had my coupe is cut about a 25-30cm square of the top of the tunnel, from the shifter towards the fire wall, the shifter is about 50-60mm back from the standard position. As mentioned before it is a tight squeeze, its hard to put oil in the gearbox unfortunatly, drop the gearbox is the only way, Automatic tunnel is bigger than the manual tunnel.
Posted on: 2008/6/7 11:33
Subject Poster Date
     ca18 in to coupe mattblack 2008/6/7 1:24
       Re: ca18 in to coupe perthute 2008/6/7 2:04
       Re: ca18 in to coupe mattdatca18 2008/6/7 2:19
         Re: ca18 in to coupe perthute 2008/6/7 2:39
           Re: ca18 in to coupe steveo 2008/6/7 11:33
       Re: ca18 in to coupe blob 2008/6/7 13:40
         Re: ca18 in to coupe _Shmity_ 2008/6/9 10:20
           Re: ca18 in to coupe crzy_1200_ute 2008/6/9 10:29
