Re: Ballast Resistor
If you have standard points distributor, you need the ballast resistor. It will work for a while without it (jump wire both terminals) but will burn the points out relatively quick.
Probably most kinds of resistor will work.
Posted on: 2008/6/16 18:47
Subject Poster Date
     Ballast Resistor Tel 2008/6/16 11:38
       Re: Ballast Resistor beattie 2008/6/16 11:47
         Re: Ballast Resistor ddgonzal 2008/6/16 18:47
