Re: surface rust again. how do i get rid of it b4 primer
From Brisbane, Australia
I don't believe in any of those "rust converters"
To remove the rust you need to hit it with a wire wheel on a grinder, or a similar rust removing wheel - whether it be a flapper wheel or disc or one of those fibre discs that look like a giant gasket remover.
Good old fish oil is a good next step. Its highly penetrative, very corrosion resistant and dries to a film you can paint over.
I like to use a kill rust type initial primer over areas that had rust, just make sure its sprayable. Then seal that with a normal automotive primer.
Posted on: 2008/6/20 5:53
Subject Poster Date
     surface rust again. how do i get rid of it b4 primer Matto1kUte 2008/6/19 18:22
       Re: surface rust again. how do i get rid of it b4 primer ddgonzal 2008/6/19 18:53
       Re: surface rust again. how do i get rid of it b4 primer Turboron 2008/6/20 0:00
         Re: surface rust again. how do i get rid of it b4 primer Mildman 2008/6/20 1:13
           Re: surface rust again. how do i get rid of it b4 primer Matto1kUte 2008/6/20 5:22
             Re: surface rust again. how do i get rid of it b4 primer L18_B110 2008/6/20 5:53
       Re: surface rust again. how do i get rid of it b4 primer blob 2008/6/20 12:34
         Re: surface rust again. how do i get rid of it b4 primer Mildman 2008/6/20 13:40
           Re: surface rust again. how do i get rid of it b4 primer Turboron 2008/6/28 5:04
             Re: surface rust again. how do i get rid of it b4 primer Mildman 2008/6/28 6:18
               Re: surface rust again. how do i get rid of it b4 primer edp 2008/6/28 19:51
                 Re: surface rust again. how do i get rid of it b4 primer Mildman 2008/6/29 8:29
                   Re: surface rust again. how do i get rid of it b4 primer rb20 2008/6/29 9:24
                     Re: surface rust again. how do i get rid of it b4 primer Mildman 2008/6/29 10:53
