Adjusting Boost on standard CA18DET
From Mandurah, Western Australia
To get my CA coupe registered the WA Liscense/Transport Department require the vehicle to generate no more than 5 psi of boost.
Im jumping through the hoops to get this car on the road, so Im not arguing or debating this issue.
I know how to up the boost, but how do you go about dropping the boost to 5psi on a stock motor with factory ECU? Do you swap the waste gate actuator? Where do you get one that will fit the T25 and open the wastegate at 5 psi? Or can you trick the system?
Cheers
Posted on: 2008/6/24 12:44
Subject Poster Date
     Adjusting Boost on standard CA18DET old_school 2008/6/24 12:44
       Re: Adjusting Boost on standard CA18DET perthute 2008/6/24 13:23
       Re: Adjusting Boost on standard CA18DET dattodude 2008/6/24 13:40
