Re: needed: sunny/stanza lca's, ball joints
From Adelaide, Australia
After 76 I think, they should just have the same length as a 1200 item just the larger bolt size and spacing for the balljoint.
Any stock rear 180b/1600 spring is pretty firm, so are front 240/260/280z springs, I think they are rated to around mid 100lb.
Posted on: 2008/8/13 13:54
cheap + fast = disaster
fast + reliable = expensive
cheap + reliable = stock
IPRA Build
Subject Poster Date
     needed: sunny/stanza lca's, ball joints rock1200 2008/8/13 12:42
       Re: needed: sunny/stanza lca's, ball joints PIGDOG 2008/8/13 12:45
         Re: needed: sunny/stanza lca's, ball joints rock1200 2008/8/13 13:31
           Re: needed: sunny/stanza lca's, ball joints WhiteSedan 2008/8/13 13:34
             Re: needed: sunny/stanza lca's, ball joints rock1200 2008/8/13 13:47
               Re: needed: sunny/stanza lca's, ball joints PIGDOG 2008/8/13 13:52
                 Re: needed: sunny/stanza lca's, ball joints rock1200 2008/8/13 13:56
                   Re: needed: sunny/stanza lca's, ball joints sssute 2008/8/13 14:36
                     Re: needed: sunny/stanza lca's, ball joints rock1200 2008/8/14 0:22
                       Re: needed: sunny/stanza lca's, ball joints Anonymous 2008/8/14 13:44
                         Re: needed: sunny/stanza lca's, ball joints rock1200 2008/8/15 0:14
                           Re: needed: sunny/stanza lca's assy (no ball joint needed) rock1200 2008/8/22 9:53
                             Re: needed: sunny/stanza lca's assy (no ball joint needed) rock1200 2008/8/25 13:35
                               Re: needed: sunny/stanza lca's assy (no ball joint needed) revhead001 2008/8/25 21:58
               Re: needed: sunny/stanza lca's, ball joints WhiteSedan 2008/8/13 13:54
