Re: What is the procedure to bleed clean hydrolic fluid system?
From South Africa, Bloemfontein
I have another idea that sounds about the same. I want to buy one of those biga$$ syringes that they use to inject cows and big farm animals.Put it on the 500mm hose,connect the other point on the bleed nipple.Loosen the nipple and pull on the syringe to cause a vacuum.This I think will also suck out the fluid and I just have to fill the top with new fluid.
Posted on: 2008/8/25 11:31
1977 Datsun 1200GX
Subject Poster Date
     What is the procedure to bleed clean hydrolic fluid system? 1200GXman 2008/8/22 14:14
       Re: What is the procedure to bleed clean hydraulic fluid system? Dodgeman 2008/8/22 21:50
         Re: What is the procedure to bleed clean hydrolic fluid system? crzy_1200_ute 2008/8/23 1:40
           Re: What is the procedure to bleed clean hydrolic fluid system? snap_point 2008/8/23 1:47
             Re: What is the procedure to bleed clean hydrolic fluid system? reuby_tuesday 2008/8/23 1:54
               Re: What is the procedure to bleed clean hydrolic fluid system? SLAM1024 2008/8/23 3:23
               Re: What is the procedure to bleed clean hydrolic fluid system? snap_point 2008/8/23 15:25
                 Re: What is the procedure to bleed clean hydrolic fluid system? 1200GXman 2008/8/25 10:19
                   Re: What is the procedure to bleed clean hydrolic fluid system? tommo73 2008/8/25 11:26
                     Re: What is the procedure to bleed clean hydrolic fluid system? 1200GXman 2008/8/25 11:31
                       Re: What is the procedure to bleed clean hydrolic fluid system? tommo73 2008/8/25 11:35
                         Re: What is the procedure to bleed clean hydrolic fluid system? WhiteSedan 2008/8/25 11:57
         Re: What is the procedure to bleed clean hydrolic fluid system? reuby_tuesday 2008/8/23 1:42
       Re: What is the procedure to bleed clean hydrolic fluid system? Dodgeman 2008/8/23 15:00
