A-series,GX,misc. 1200 parts for sale. Make offer!
I have some A-series,GX,misc. 1200 parts for sale.Here is what I have. (2) GX dual su intake manifolds,have heatshield for one of them,it's kind of rusty but canbe cleaned up and used. (1) linkage arm that goes between carbs. (1) box full of su carb. parts.some parts are rusty and are probably no good but there are alot of parts you could probably almost put together a set or just use the parts. (1) GX exhaust manifold (1) GX cyl. head,some valves,no springs,been sitting around. (1) A-15 crankshaft with new main bearings. (1) camshaft re-ground by Isky with lifters,cam fits A-14 ,etc. forgot specs. if you can find an old isky book it shouldbe in there.This is a great cam! In the early-mid 80's before the modern hondas,etc. I had a 1200,with A-14 shortblock,GX head and this cam.The car would clean house at the street races often beating cars with dual carbs and much bigger engines.It was one hell of a sleeper! (1) timing chain set,etc.,front cover,crank pulley,small A-12 one. (1) electronic dist. (1) factory 1200 8000rpm tach (1) heavy duty 1200 radiator (1) complete 1200 differential with 4.62 ring&pinion,not limited slip. (1) 1200 driveshaft. also have a box with some misc parts,trans mount,shifter ,etc. Also have hard to find 1200 GX hood. Make me an offer on some of it or all of it,no resonable offer refused, name your price,it all must go quickly! You can contact me at jrazo9@aol.com or call me . Mike (562)440-3764. I live in the USA, Los Angles, California.
Posted on: 2008/8/25 23:00
Subject Poster Date
     A-series,GX,misc. 1200 parts for sale. Make offer! ex1200racer 2008/8/25 23:00
       Re: A-series,GX,misc. 1200 parts for sale. Make offer! NIS2000 2008/8/26 0:54
         Re: A-series,GX,misc. 1200 parts for sale. Make offer! Mitch_photog 2008/8/26 1:51
