Re: A completely different A-series build!
Dodgeman wrote:
I believe [but don't quote me] that it is capable of maintaining a balance of hot & cold air to maintain a constant air temperature into the carb. If this is true, then you couldn't ask for more. The carb can then be tuned for optimum efficiency & it will maintain that efficiency for as long as the engine is running once it has warmed up a little.
As that well known drag racer, Smokey Unick often said, ... "bring your variables under control" Wise words to remember.
ddgonzal wrote:
The idea is not to take "hot" air, but to take air at a constant temperature. Then you jet it lean within an inch of its life and be assured it won't vary as you are driving and drop even leaner and destroy the engine. In practical terms this means hotter than outside temperature so that you regulate the temp. Cooling the air is tricky.
Different words but same thought. Heated air will convert liquid fuel in the form of droplets into a gas much more quickly & efficiently than cold air ever will & as we now know, liquid fuel will not burn, only the gaseous form of it.
High manifold vacuum will also help here as the fuel droplets inside the manifold will boil at a much lower temperature at low pressures but this conversion from liquid to a gaseous state also sucks a lot of heat from the surrounding air inside the manifold, so heated air going in is a compensation for this.
This temperature drop when converting to a gas is a well known refrigeration principal known as 'latent heat of evaporation' & is the same principal that your evaporative room cooler works on.
Posted on: 2009/10/21 17:40
Love your Datsun.
Treat it well.
Subject Poster Date
     A completely different A-series build! blownb310 2008/8/29 3:06
       Re: A completely different A-series build! Anonymous 2008/8/29 3:10
         Re: A completely different A-series build! Dodgeman 2008/8/29 3:49
           Re: A completely different A-series build! Rallytwit 2008/8/29 3:57
             Re: A completely different A-series build! PIGDOG 2008/8/29 4:11
               Re: A completely different A-series build! 1000Coupe 2008/8/29 5:31
                 Re: A completely different A-series build! Dodgeman 2008/8/29 13:42
                   Re: A completely different A-series build! beattie 2008/8/29 14:26
                     Re: A completely different A-series build! Dodgeman 2008/8/29 14:46
                       Re: A completely different A-series build! blownb310 2008/8/29 15:18
                         Re: A completely different A-series build! Dodgeman 2008/8/29 15:45
                           Re: A completely different A-series build! blownb310 2008/8/29 16:01
                             Re: A completely different A-series build! Dodgeman 2008/8/29 16:06
                               Re: A completely different A-series build! kelmo 2008/8/29 19:33
                                 Re: A completely different A-series build! blownb310 2008/8/29 20:28
                                   Re: A completely different A-series build! blownb310 2008/8/30 13:42
                                     Re: A completely different A-series build! Anonymous 2008/8/30 14:00
                                       Re: A completely different A-series build! blownb310 2008/8/30 14:14
                                       Re: A completely different A-series build! supafatto 2008/8/30 14:15
                                         Re: A completely different A-series build! kelmo 2008/8/30 21:20
                               Re: A completely different A-series build! Fandatstick 2008/8/31 10:36
                                 Re: A completely different A-series build! Dodgeman 2008/8/31 15:32
                                   Re: A completely different A-series build! blownb310 2008/9/1 3:41
                                     Re: A completely different A-series build! 1000Coupe 2008/9/2 4:35
       Re: A completely different A-series build! ddgonzal 2008/8/29 6:23
         Re: A completely different A-series build! cheater_5 2008/8/29 7:04
         Re: A completely different A-series build! Sumith 2009/4/21 8:54
           Re: A completely different A-series build! ddgonzal 2009/4/21 17:50
           Re: A completely different A-series build! blownb310 2009/4/22 2:37
             Re: A completely different A-series build! LONGBROW 2009/4/23 4:01
               Re: A completely different A-series build! 1000Coupe 2009/4/23 4:22
             Re: A completely different A-series build! Sumith 2009/4/24 9:10
               Re: A completely different A-series build! ddgonzal 2009/4/25 6:47
                 Re: A completely different A-series build! blownb310 2009/4/30 3:30
                   Re: A completely different A-series build! ddgonzal 2009/4/30 6:35
                   Re: A completely different A-series build! B2Slow 2009/5/2 7:32
                     Re: A completely different A-series build! blownb310 2009/5/28 2:09
                   Re: A completely different A-series build! blownb310 2009/5/28 2:01
                     Re: A completely different A-series build! ddgonzal 2009/5/28 5:03
                       Re: A completely different A-series build! blownb310 2009/5/29 0:21
                         Re: A completely different A-series build! ddgonzal 2009/5/30 6:22
                           Re: A completely different A-series build! blownb310 2009/6/15 18:58
                             Re: A completely different A-series build! ddgonzal 2009/6/17 6:19
                               Re: A completely different A-series build! blownb310 2009/6/18 3:26
                                 Re: A completely different A-series build! ddgonzal 2009/6/18 4:36
                       Re: A completely different A-series build! Dodgeman 2009/7/18 18:34
       Re: A completely different A-series build! sikyne 2008/8/31 1:24
         Re: A completely different A-series build! D 2008/8/31 4:35
           Re: A completely different A-series build! dazza1200 2008/8/31 4:52
           Re: A completely different A-series build! Dodgeman 2008/8/31 5:27
             Re: A completely different A-series build! Dodgeman 2008/9/13 12:00
               Re: A completely different A-series build! blownb310 2008/9/28 4:05
                 Re: A completely different A-series build! blownb310 2008/10/4 3:17
                   Re: A completely different A-series build! Dundee1000 2008/10/4 4:30
                     Re: A completely different A-series build! Mildman 2008/10/4 4:33
                       Re: A new A-series mpg record? blownb310 2008/10/9 2:55
                         Re: A new A-series mpg record? Ianey 2008/10/9 3:59
                           Re: A new A-series mpg record? wolki101 2008/10/9 4:06
                             Re: A new A-series mpg record? LittleFireyOne 2008/10/10 1:42
                               Re: A new A-series mpg record? blownb310 2008/10/10 13:31
                                 Re: A new A-series mpg record? Dodgeman 2008/10/14 3:33
                                   Re: A new A-series mpg record? blownb310 2008/10/14 3:46
                                     Re: A new A-series mpg record? ROConnor 2008/10/14 7:30
                                       Re: A new A-series mpg record? Dodgeman 2008/10/14 9:31
                                 Re: A new A-series mpg record? Fandatstick 2008/10/16 10:27
                                   Re: A new A-series mpg record? Dodgeman 2008/10/16 10:56
                                     Re: A new A-series mpg record? ROConnor 2008/10/16 11:24
                                     Re: A new A-series mpg record? Fandatstick 2008/10/18 14:00
                                       Re: A new A-series mpg record? blownb310 2008/10/25 0:37
                                         Re: A new A-series mpg record? Rallytwit 2008/10/25 3:02
                                           Re: A new A-series mpg record? Dodgeman 2008/10/25 3:44
                                             Re: A new A-series mpg record? blownb310 2008/10/25 3:57
                                               Re: A new A-series mpg record? Dodgeman 2008/10/25 5:11
                                                 Re: A new A-series mpg record? ROConnor 2008/10/25 7:36
                                                   Re: A new A-series mpg record? blownb310 2008/10/25 14:47
                                                     Re: A new A-series mpg record? Datsunitus 2008/10/25 16:19
                                                       Re: A new A-series mpg record? blownb310 2008/10/25 16:23
                                                         Re: A new A-series mpg record? Datsunitus 2008/10/25 16:25
                                                           Re: A new A-series mpg record? blownb310 2008/10/25 16:26
                                                       Re: A new A-series mpg record? Gary_P 2008/10/25 16:37
                                                         Re: A new A-series mpg record? Datsunitus 2008/10/25 17:15
                                                           Re: A new A-series mpg record? Gary_P 2008/10/25 19:41
                                                     Re: A new A-series mpg record? Dodgeman 2008/10/26 1:00
                                                       Re: A new A-series mpg record? D 2008/10/26 1:50
                                                         Re: A new A-series mpg record? ROConnor 2008/10/26 6:30
                                                           Re: A new A-series mpg record? D 2008/10/27 13:58
                                                       Re: A new A-series mpg record? blownb310 2008/10/27 19:37
                                                         Re: A new A-series mpg record? femtnmax 2008/12/1 3:28
                                                           Re: A new A-series mpg record? blownb310 2008/12/1 3:47
                                                             Re: A new A-series mpg record? femtnmax 2008/12/6 3:45
                                                               Re: A new A-series mpg record? blownb310 2008/12/6 4:19
        Re: A new A-series mpg record? femtnmax 2008/12/7 2:32
        Re: A new A-series mpg record? blownb310 2008/12/7 15:00
        Re: A new A-series mpg record? femtnmax 2008/12/8 3:05
        Re: A new A-series mpg record? ddgonzal 2008/12/13 11:07
        Re: A completely different A-series build! blownb310 2009/4/20 16:13
        Re: A completely different A-series build! Gary_P 2009/4/20 17:19
        Re: A completely different A-series build! blownb310 2009/4/21 3:42
        Re: A completely different A-series build! ddgonzal 2009/4/21 5:42
                           Re: A new A-series mpg record? Fandatstick 2008/10/14 2:49
                             Re: A new A-series mpg record? blownb310 2008/10/14 3:13
       Re: A completely different A-series build! pager 2008/9/1 4:05
         Re: A completely different A-series build! D 2008/9/2 4:03
           Re: A completely different A-series build! Dodgeman 2008/9/2 10:18
             Re: A completely different A-series build! reuby_tuesday 2008/9/2 11:49
               Re: A completely different A-series build! Dundee1000 2008/9/2 12:39
                 Re: A completely different A-series build! reuby_tuesday 2008/9/2 12:56
             Re: A completely different A-series build! blownb310 2008/9/2 12:58
               Re: A completely different A-series build! dazza1200 2008/9/3 13:19
                 Re: A completely different A-series build! blownb310 2008/9/3 22:27
                   Re: A completely different A-series build! Dodgeman 2008/9/4 0:21
                     Re: A completely different A-series build! blownb310 2008/9/4 1:30
                     Re: A completely different A-series build! blownb310 2008/9/4 1:35
                       Re: A completely different A-series build! Dodgeman 2008/9/4 2:53
                         Re: A completely different A-series build! racinaround 2008/9/4 4:05
                           Re: A completely different A-series build! blownb310 2008/9/4 4:28
                             Re: A completely different A-series build! blownb310 2008/9/4 4:33
                         Re: A completely different A-series build! Gary_P 2008/9/4 4:39
                           Re: A completely different A-series build! blownb310 2008/9/11 1:58
                             Re: A completely different A-series build! Fandatstick 2008/9/13 11:35
       Re: A completely different A-series build! DaveB 2008/9/2 5:12
         Re: A completely different A-series build! pager 2008/9/2 6:28
       Re: A completely different A-series build! LONGBROW 2009/4/24 1:54
       Re: A completely different A-series build! blownb310 2009/7/18 3:16
       Re: A completely different A-series build! blownb310 2009/7/20 13:08
       Re: A completely different A-series build! superbin 2009/7/20 14:48
         Re: A completely different A-series build! ddgonzal 2009/7/20 18:08
       Re: A completely different A-series build! billybuilt 2009/7/20 21:07
         Re: A completely different A-series build! ddgonzal 2009/7/21 0:51
         Re: A completely different A-series build! D 2009/7/21 0:57
       Re: A completely different A-series build! jmac 2009/7/21 10:52
         Re: A completely different A-series build! D 2009/7/21 11:10
           Re: A completely different A-series build! Dodgeman 2009/7/21 16:42
             Re: A completely different A-series build! ddgonzal 2009/7/21 17:18
           Re: A completely different A-series build! D 2009/7/23 2:41
             Re: A completely different A-series build! ddgonzal 2009/7/23 4:17
               Re: A completely different A-series build! D 2009/7/23 5:06
               Re: A completely different A-series build! blownb310 2009/7/29 3:53
       Re: A completely different A-series build! superbin 2009/7/23 7:40
       Re: A completely different A-series build! benny 2009/7/23 7:50
       Re: A completely different A-series build! blownb310 2009/7/29 3:48
         Re: A completely different A-series build! Dodgeman 2009/7/29 17:34
           Re: A completely different A-series build! blownb310 2009/7/30 2:34
           Re: A completely different A-series build! D 2009/7/30 2:36
             Re: A completely different A-series build! 1000Coupe 2009/7/30 3:53
       Re: A completely different A-series build! jmac 2009/7/29 4:35
       Re: A completely different A-series build! blownb310 2009/8/2 20:19
         Re: A completely different A-series build! ddgonzal 2009/8/3 0:54
           Re: A completely different A-series build! blownb310 2009/8/3 3:02
             Re: A completely different A-series build! Dodgeman 2009/8/5 15:53
       Re: A completely different A-series build! ang94541 2009/8/6 1:35
         Re: A completely different A-series build! blownb310 2009/8/10 18:49
       Re: A completely different A-series build! D 2009/8/6 5:09
         Re: A completely different A-series build! blownb310 2009/8/10 18:51
           Re: A completely different A-series build! ddgonzal 2009/8/12 7:01
             Re: A completely different A-series build! blownb310 2009/8/14 19:29
       Re: A completely different A-series build! superbin 2009/8/14 19:45
         Re: A completely different A-series build! D 2009/8/15 0:13
       Re: A completely different A-series build! blownb310 2009/8/15 4:44
       Re: A completely different A-series build! blownb310 2009/8/15 4:50
       Re: A completely different A-series build! blownb310 2009/8/16 2:19
       Re: A completely different A-series build! blownb310 2009/8/18 2:49
       Re: A completely different A-series build! 1000Coupe 2009/8/18 3:03
         Re: A completely different A-series build! D 2009/8/18 6:08
           Re: A completely different A-series build! blownb310 2009/8/21 17:59
             Re: A completely different A-series build! ang94541 2009/8/25 5:37
               Another new record! blownb310 2009/8/28 0:30
                 Re: A completely different A-series build! D 2009/8/28 0:59
                   Re: A completely different A-series build! ddgonzal 2009/8/28 6:54
                     Re: A completely different A-series build! blownb310 2009/8/28 15:55
                       Re: A completely different A-series build! D 2009/8/29 2:26
                       Re: A completely different A-series build! ddgonzal 2009/8/29 5:57
                         Re: A completely different A-series build! Rallytwit 2009/8/29 6:24
                           Re: A completely different A-series build! ROConnor 2009/8/29 6:28
                             Re: A completely different A-series build! blownb310 2009/9/5 21:56
                       Re: A completely different A-series build! Dodgeman 2009/8/31 14:53
                         Re: A completely different A-series build! blownb310 2009/9/5 22:01
                           Re: A completely different A-series build! Fandatstick 2009/9/6 10:31
                             Re: A completely different A-series build! blownb310 2009/9/6 21:29
                               Re: A completely different A-series build! Dodgeman 2009/10/19 6:56
                       Re: A completely different A-series build! ang94541 2009/9/1 4:42
       Re: A completely different A-series build! superbin 2009/8/28 7:24
       Re: A completely different A-series build! 1000Coupe 2009/10/20 2:56
         Re: A completely different A-series build! ddgonzal 2009/10/20 3:47
           Re: A completely different A-series build! 1000Coupe 2009/10/20 4:58
           Re: A completely different A-series build! Dodgeman 2009/10/21 17:40
       Re: A completely different A-series build! lamb_daiquiri 2011/6/4 0:59
       Re: A completely different A-series build! blownb310 2011/6/5 3:22
       Re: A completely different A-series build! ddgonzal 2011/6/5 3:56
