go fast bits etc
From australia tasmania
Here are a pair of used FC 4pot callipers.
They are in working condition and will receive a thorough clean and high temp painting before being sent out.
They are have not rebuilt but i can also offer this at an additional fee.
These are a excellent calliper and are a ideal upgrade as opposed to aftermarket callipers which have limited pad choices. These are backed by many aftermarket pads ranging for ome replacement to high friction race pads.
Price is $240 (competitors charge upward of $300)
Postage available
have a few ignition parts for different applications. all items are used.
multi coils $200
simerla to michrotech ones, was running on a 4age with wolf 3D. worked very well, grate spark. they dont runnout of much at high revs either like a single coil set-up
[URL=http://imageshack.us]Open in new window
[/URL]
[/URL]
ignition module $100
includes plugs for it
[/URL]
[/URL]
APEX'i Super Air Flow Controller (S-AFC) $220
includes the wiring to adapt it to suit a wide range of applications
[/URL]
[/URL]
from the net here is an explanation on what id does ;)
The Super Air Flow Converter can change the fuel amount up to /- 50% at 8 specific RPM levels
Characteristics
Modifies air-flow meter signal (pressure signal in some vehicles) to optimize fuel-air ratio; Vacuum Fluorescent Display (VFD).
Comments
The S-AFC is a fuel computer that adjusts fuel/air ratio by modifying the air-flow meter/MAP sensor signal. The S-AFC features a user-definable, eight-point, adjustable fuel curve that can be set in 500 RPM increments. The range of fuel adjustment is /- 50% at each of the user-defined setting points. On hot-wire vehicles, the Deceleration Air Flow Correction function is capable of curing the erratic idle and stall problems associated with open-atmosphere blow-off valves on hot-wire air-flow meter systems. The S-AFC is capable of monitoring and replaying the following data channels in Numerical, Analog Meter and Graph displays: Intake Manifold Vacuum/Boost Pressure, Air Flow Capacity, Intake Manifold Pressure, Karmann Frequency, Engine RPM, Throttle Position, and Air Flow Correction %.
Posted on: 2008/9/14 12:35
old skool cool...
www.shakotangarage.com
Subject Poster Date
     go fast bits etc akinaspeedstar 2008/9/14 12:35
       Re: go fast bits etc akinaspeedstar 2008/10/2 5:16
         Re: go fast bits etc akinaspeedstar 2008/10/7 4:28
