Re: Front spring Dimensions+rates?
From Sydney
150 - 175lbs for street duties with a comfort ride, 200-225lbs for street duties with a sports ride, 250 -275lbs for the track. If you are going down the coil over route, I would go with the 65mm ID springs as they seem to be the most common these days. [in Australia that is]
I run 63mm [2.5"] springs and find it a little hard at times to find the parts im after at a competitive price.
Posted on: 2008/9/24 7:41
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Subject Poster Date
     Front spring Dimensions+rates? ROConnor 2008/9/23 8:52
       Re: Front spring Dimensions+rates? Anonymous 2008/9/23 13:28
       Re: Front spring Dimensions+rates? rock1200 2008/9/24 5:36
         Re: Front spring Dimensions+rates? bobthebuilder 2008/9/24 6:50
           Re: Front spring Dimensions+rates? benny 2008/9/24 7:41
             Re: Front spring Dimensions+rates? ROConnor 2008/9/24 7:47
           Re: Front spring Dimensions+rates? rock1200 2008/9/24 14:17
             Re: Front spring Dimensions+rates? bobthebuilder 2008/9/24 22:18
               Re: Front spring Dimensions+rates? Anonymous 2008/9/24 23:02
               Re: Front spring Dimensions+rates? rock1200 2008/9/25 3:35
                 Re: Front spring Dimensions+rates? bobthebuilder 2008/9/25 7:17
                   Re: Front spring Dimensions+rates? rock1200 2008/9/25 12:57
         Re: Front spring Dimensions+rates? ddgonzal 2008/9/25 3:15
