Re: Headlight Wiring
From South Africa
I already have crystal headlights installed with Xenon globes. I was told to put relays on each one, which I will be doing, but I want the Low and High beam to work together when I switch the high beam on. Will this cause anything to melt. Im not worried about amps as each globe will run throught a 30A relay which goes straight to the battery.
Posted on: 2008/10/2 16:22
___________________________________
2006 Ford Bantam
2004 Ford Ikon
Subject Poster Date
     Headlight Wiring Velociti 2008/10/2 9:54
       Re: Headlight Wiring bailz 2008/10/2 10:24
         Re: Headlight Wiring Velociti 2008/10/2 16:22
           Re: Headlight Wiring DatsAndy 2008/10/3 0:22
