s13 strut conversion
From Brisvegas, oz
does anybody know if the standard 1200 outer tie rods can be used when doing the s13 strut conversion or do you need to use the s13 ones. the measurements are the hole size is about 0.5 mm larger on the s13 side than the 1200 ones and the plate is about 2 mm wider.
Posted on: 2008/10/5 1:55
www.camerasplus.com.au
Subject Poster Date
     s13 strut conversion frankthedolphintrainer 2008/10/5 1:55
       Re: s13 strut conversion dongdong0507 2008/10/5 3:51
         Re: s13 strut conversion frankthedolphintrainer 2008/10/5 4:14
