Re: question about a12 head on a14
The round port heads on 1200's & A12's use 35 & 29mm valve sizes. The A14 uses 37 & 30mm valves.
You can port out an early head all you like & you still won't match the A14 head for port size right through to the valve.
Simply put, the factory matched each head well to the engine & its intended use.
If you use a small port head on the larger engines that came with an oval port head you will limit the upper end of the performance range.
By all means use a small port head to keep you mobile untill you can find a suitable replacement A14 head, or untill you can fix your old head, but I would never regard it as a permanant replacement unless the engine was intended as an industrial powerplant, or the vehicle was used in serious economy events.
Posted on: 2008/10/14 9:48
Love your Datsun.
Treat it well.
Subject Poster Date
     question about a12 head on a14 aidaniel 2008/10/13 3:12
       Re: question about a12 head on a14 tommo73 2008/10/13 9:12
         Re: question about a12 head on a14 cheater_5 2008/10/13 9:20
           Re: question about a12 head on a14 aidaniel 2008/10/13 10:46
             Re: question about a12 head on a14 ROConnor 2008/10/13 10:54
               Re: question about a12 head on a14 aidaniel 2008/10/14 9:40
                 Re: question about a12 head on a14 Dodgeman 2008/10/14 9:48
                   Re: question about a12 head on a14 aidaniel 2008/10/14 9:55
                   Re: question about a12 head on a14 steveo 2008/10/14 10:19
                     Re: question about a12 head on a14 aidaniel 2008/10/14 10:23
                       Re: question about a12 head on a14 Petemagete 2008/10/16 20:18
