Re: has anyone had this problem???
From Perth WA AUS
Sounds like the guages are earthing out fully, pretty sure they rely on variable negative power to give a reading. The unit is fed constant positive (with ignition on) but the sender varies the negative (more negative (Earth) heats up the Bi-metal strip and give a higher reading on the guage), anyway, sounds like an earth short.
Posted on: 2008/10/25 15:15
Datsun 1200 2Dr sedan.
Subject Poster Date
     has anyone had this problem??? nzdattoman 2008/10/23 22:35
       Re: has anyone had this problem??? ohbeh4ve 2008/10/23 23:19
         Re: has anyone had this problem??? DattoFrog 2008/10/23 23:41
           Re: has anyone had this problem??? Graemes50 2008/10/24 0:45
             Re: has anyone had this problem??? Rallytwit 2008/10/24 2:06
       Re: has anyone had this problem??? Dodgeman 2008/10/24 3:42
         Re: has anyone had this problem??? nzdattoman 2008/10/24 7:34
           Re: has anyone had this problem??? LONGBROW 2008/10/24 14:40
             Re: has anyone had this problem??? nzdattoman 2008/10/24 21:21
               Re: has anyone had this problem??? LONGBROW 2008/10/25 5:04
               Re: has anyone had this problem??? levey 2008/10/25 15:15
                 Re: has anyone had this problem??? nzdattoman 2008/10/26 7:39
                   Re: has anyone had this problem??? nzdattoman 2008/10/26 7:41
