Re: REMOVING UNIVERSAL FROM DATSUN 1200 UTE DRIVESHAFT
From sydney australia
The universals are peined in, which is where they fold over the metal of the housings to retain the uni. This was so you had to buy a complete new tailshaft. The best replacement uni's are the standard 1200 ones, but you need to get the front & back fittings machined out to take the new uni's. You also need to get the rememnants of the old unis out, usually at the same time. Personally i would cut the uni's so you'd end up with a front yoke, tailshaft & a rear yoke, then take those along to the tailshaft place,as this would probably be the first thing they would do. Unfortunately this immobilises the car, as you no longer have a tailshaft. Early Datsuns use the same uni's as HQ-HZ Holdens, so the replaceable uni's are readily available. After this first bit, the replacement of uni's is like any other car.
Posted on: 2008/10/28 0:43
Subject Poster Date
     REMOVING UNIVERSAL FROM DATSUN 1200 UTE DRIVESHAFT Cameron 2008/10/26 9:58
       Re: REMOVING UNIVERSAL FROM DATSUN 1200 UTE DRIVESHAFT ANGE 2008/10/26 10:02
         Re: REMOVING UNIVERSAL FROM DATSUN 1200 UTE DRIVESHAFT 1200rallycar 2008/10/26 10:07
         Re: REMOVING UNIVERSAL FROM DATSUN 1200 UTE DRIVESHAFT QKCOOP 2008/10/26 10:09
           Re: REMOVING UNIVERSAL FROM DATSUN 1200 UTE DRIVESHAFT DattoFrog 2008/10/26 13:40
             Re: REMOVING UNIVERSAL FROM DATSUN 1200 UTE DRIVESHAFT benddatsun 2008/10/26 22:10
               Re: REMOVING UNIVERSAL FROM DATSUN 1200 UTE DRIVESHAFT b310gx 2008/10/28 0:43
                 Re: REMOVING UNIVERSAL FROM DATSUN 1200 UTE DRIVESHAFT chris_stam 2008/10/28 1:30
                   Re: REMOVING UNIVERSAL FROM DATSUN 1200 UTE DRIVESHAFT PIGDOG 2008/10/28 4:10
                     Re: REMOVING UNIVERSAL FROM DATSUN 1200 UTE DRIVESHAFT 1200rallycar 2008/10/28 6:05
