Re: 63 series 5 speed question.
From sydney australia
Woodie, I dont think there was a 63A 5 speed that wasn't a dogleg box. All the normal boxes were the 71a's, with 71 mm's between the shafts. Are you sure this isn't a normal 4 speed with worn shifters so it'll slip into the 5 position & there wasn't anything there, like some 56a 4 speeds. Even the 63a 5 speed in the 200B coupe was a dogleg box. Check the case for the number on the side, or whether the output shaft will turn when you put the shifter into the 5th position. & if you want to go to a normal shift pattern, my racing partner has a normal pattern 5 speed 60a, maybe he'll be open to a swap. We'll be pit crewing at the Australian championships, so maybe we could have a chat then. Paul.
Posted on: 2008/10/28 0:15
Subject Poster Date
     63 series 5 speed question. woody 2008/10/27 8:42
       Re: 63 series 5 speed question. datto1000wagon 2008/10/27 8:57
         Re: 63 series 5 speed question. woody 2008/10/27 8:59
           Re: 63 series 5 speed question. Anonymous 2008/10/27 10:41
             Re: 63 series 5 speed question. WhiteSedan 2008/10/27 10:44
               Re: 63 series 5 speed question. woody 2008/10/27 10:46
                 Re: 63 series 5 speed question. b310gx 2008/10/28 0:15
                   Re: 63 series 5 speed question. A14force 2008/10/28 7:17
                     Re: 63 series 5 speed question. revhead001 2008/10/28 9:17
                       Re: 63 series 5 speed question. woody 2008/10/28 10:09
                         Re: 63 series 5 speed question. revhead001 2008/10/28 20:05
                           Re: 63 series 5 speed question. A14force 2008/10/29 4:14
                   Re: 63 series 5 speed question. PIGDOG 2008/10/29 6:10
                     Re: 63 series 5 speed question. woody 2008/10/29 8:47
                       Re: 63 series 5 speed question. A14force 2008/10/30 3:57
