Re: 1200 ute ca det fast idle- 2000rpm??????
From brisbane
what is the tps. this is my first fuel injected car, so all these abreviations are doing my head in, i know what maf, pcv and cts are but what about IAV.???? i haven't tried the throttle control sensor yet as i've been trying to get it on the road which happened friday, so will this week. a new electronic idle control sensor is about 180 from nissan but i will try a second hand on from alljap or somethingfirst i think.just annoying.the lowest mine will idle once warm has been about 1700 or so. but usually about 2000, sometime 2500.
i am using the stock tacho!!!! how would i adjust the throttle sensor..... if u mean the actuator off the cable on the side of the inlet manifold then its fine, there is a few mil slack and seems to be ok. before it warms up it idle rough and cold and wants to die but after a minute or two its ok about 1500... as it get warmer it idles higher and higher
Posted on: 2008/12/16 4:47
A15 1200 ute, 77 mini -b16a honda vtec project
Subject Poster Date
     1200 ute ca det fast idle- 2000rpm?????? bugsie 2008/11/15 6:50
       Re: 1200 ute ca det fast idle- 2000rpm?????? lethal_john 2008/11/15 9:54
         Re: 1200 ute ca det fast idle- 2000rpm?????? kegs 2008/11/15 9:59
           Re: 1200 ute ca det fast idle- 2000rpm?????? lethal_john 2008/11/15 11:25
             Re: 1200 ute ca det fast idle- 2000rpm?????? bugsie 2008/11/16 5:47
               Re: 1200 ute ca det fast idle- 2000rpm?????? Daveman 2008/11/16 6:11
                 Re: 1200 ute ca det fast idle- 2000rpm?????? bugsie 2008/11/16 20:11
                   Re: 1200 ute ca det fast idle- 2000rpm?????? kegs 2008/12/3 10:35
                     Re: 1200 ute ca det fast idle- 2000rpm?????? short-coupe 2008/12/3 11:53
                       Re: 1200 ute ca det fast idle- 2000rpm?????? dazza1200 2008/12/3 12:11
                     Re: 1200 ute ca det fast idle- 2000rpm?????? bugsie 2008/12/16 4:47
                       Re: 1200 ute ca det fast idle- 2000rpm?????? _Shmity_ 2008/12/18 5:55
