Re: Front Wheel bearing grease leaking!
well now it gets the wheel dirty. I would replace the grease cap to stop the leak.
yes wheel bearing grease gets somewhat liquid. Be sure you are using grease "for disc brakes" if your 1200 has disc brakes, it can handle the high temperatures that disc brakes generates.
Posted on: 2008/12/11 16:00
Subject Poster Date
     Front Wheel bearing grease leaking! Ethan 2008/12/11 14:07
       Re: Front Wheel bearing grease leaking! ddgonzal 2008/12/11 14:32
         Re: Front Wheel bearing grease leaking! Ethan 2008/12/11 15:13
           Re: Front Wheel bearing grease leaking! ddgonzal 2008/12/11 16:00
             Re: Front Wheel bearing grease leaking! DUMBO 2008/12/12 9:14
               Re: Front Wheel bearing grease leaking! Ethan 2008/12/12 9:25
