Browsing this Thread:
1 Anonymous Users
Re: wtb throttle upgrade for ca18det |
From Christchurch
SR20DE throttle body is the go a few mates have done it, bolts on to the ca plenum just need to port match it the manifold. Its 60mm Vs 54mm for the CA. It would probably be safer to get a silvia one as I have a feeling FWD sr20 throttle bodies have a different bolt pattern, although I can't confirm. Although if the fwd ones have the same bolt pattern you could buy a N1 sr16ve throttle body they are 70mm, but you'd have to buy one new through nissan as you'd never find a 2nd hand one (n1 sr16ve pulsars were built in the hundreds) . Unsure on the price but could probably russle up a p/n for you if you were keen.
Posted on: 2008/12/21 21:21
