Re: Well I guess I did it.
From Snohomish, WA USA
Well, broke the left axle shaft inside the bearings on the pumkin. I guess that's the reason why it never broke loose and rattle inside my rear diff. Replace the bearing and axle and it's fixed but I'm not going to go that route. Think I'll pick up something a bit beefy'r.
Are H150, H165 or H190 the same width, drum to drum? How about the drive shaft bolt up pattern?
I want to make the swap over as simple as possible.
Thanks.
Posted on: 2009/1/6 0:00
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
Subject Poster Date
     Well I guess I did it. datsa73 2009/1/3 3:22
       Re: Well I guess I did it. PIGDOG 2009/1/3 3:39
         Re: Well I guess I did it. datsa73 2009/1/3 4:01
           Re: Well I guess I did it. PIGDOG 2009/1/3 4:24
             Re: Well I guess I did it. datsa73 2009/1/3 4:48
               Re: Well I guess I did it. PIGDOG 2009/1/3 5:16
                 Re: Well I guess I did it. A14force 2009/1/3 22:21
                   Re: Well I guess I did it. datsa73 2009/1/5 6:00
                     Re: Well I guess I did it. ddgonzal 2009/1/5 6:18
                       Re: Well I guess I did it. TUF-110 2009/1/5 8:24
                         Re: Well I guess I did it. PIGDOG 2009/1/5 8:39
                           Re: Well I guess I did it. Dodgeman 2009/1/5 10:38
                             Re: Well I guess I did it. A14force 2009/1/5 20:22
                               Re: Well I guess I did it. datsa73 2009/1/6 0:00
                                 Re: Well I guess I did it. wolki101 2009/1/6 0:20
                                   Re: Well I guess I did it. ddgonzal 2009/1/6 3:14
