Re: bonnet vents/scoops
From newcastle, NSW
thanks steveo i vision it to be like that, got a better pic
Sorry champ, thats pretty much the only pic i've got. There may be another in my album, i'm not sure. Its quite easy to do, i just cut the ford bonnet up around the flutes and then cut the same shape in the 1200 bonnet, i used a dove tail joint but you could also just 'but' joint it and then tack it together. I also used the ford supports on the underside of the bonnet to re-enforce it all together.
Must use bonnet pins though! i strongly recomend it! the bonnet is inclined to fly up without notice if not latched and secured properly.
Posted on: 2009/1/17 9:53
Subject Poster Date
     bonnet vents/scoops hotrocket 2009/1/15 20:09
       Re: bonnet vents/scoops hotrocket 2009/1/15 20:24
         Re: bonnet vents/scoops kegs 2009/1/15 23:42
           Re: bonnet vents/scoops hotrocket 2009/1/16 4:34
             Re: bonnet vents/scoops datski620 2009/1/16 9:28
               Re: bonnet vents/scoops ROConnor 2009/1/16 9:41
                 Re: bonnet vents/scoops steveo 2009/1/16 9:51
                   Re: bonnet vents/scoops hotrocket 2009/1/16 11:46
                     Re: bonnet vents/scoops steveo 2009/1/17 9:53
                 Re: bonnet vents/scoops aidaniel 2009/1/16 11:49
                   Re: bonnet vents/scoops 1200rallycar 2009/1/16 11:55
                   Re: bonnet vents/scoops ROConnor 2009/1/16 11:57
                     Re: bonnet vents/scoops ROConnor 2009/1/16 12:01
                       Re: bonnet vents/scoops K-DOGG 2009/1/16 12:33
                         Re: bonnet vents/scoops hotrocket 2009/1/16 19:48
                           Re: bonnet vents/scoops aidaniel 2009/1/17 7:53
                             Re: bonnet vents/scoops hotrocket 2009/1/17 7:57
                             Re: bonnet vents/scoops ROConnor 2009/1/17 7:58
                               Re: bonnet vents/scoops ROConnor 2009/1/17 8:03
