Re: 32mm Keihin carbs in A14?? would it work?
Quite a regular
You should be ok to have them on a slight lean if anything lean them so that the air is travelling 'downhill' into the engine.
Too much angle will f--k with the operation of the floats in the bowls though...
youll end up having to stuff around with the floats to make sure theyre holding the right amount of fuel.
Posted on: 2009/2/13 1:50
Subject Poster Date
     32mm Keihin carbs in A14?? would it work? Bandit_blues 2009/2/5 12:57
       Re: 32mm Keihin carbs in A14?? would it work? cheater_5 2009/2/5 20:34
         Re: 32mm Keihin carbs in A14?? would it work? TUF-110 2009/2/5 20:36
           Re: 32mm Keihin carbs in A14?? would it work? Bandit_blues 2009/2/10 18:02
             Re: 32mm Keihin carbs in A14?? would it work? clyons8 2009/2/10 21:18
               Re: 32mm Keihin carbs in A14?? would it work? clyons8 2009/2/10 21:19
                 Re: 32mm Keihin carbs in A14?? would it work? TUF-110 2009/2/11 8:51
               Re: 32mm Keihin carbs in A14?? would it work? ddgonzal 2009/2/11 3:13
                 Re: 32mm Keihin carbs in A14?? would it work? cheater_5 2009/2/11 7:48
                   Re: 32mm Keihin carbs in A14?? would it work? 1200GXman 2009/2/11 8:31
                     Re: 32mm Keihin carbs in A14?? would it work? ROConnor 2009/2/11 9:04
                     Re: 32mm Keihin carbs in A14?? would it work? kululadotgroen 2009/2/11 9:18
                       Re: 32mm Keihin carbs in A14?? would it work? DattoFrog 2009/2/12 3:57
                         Re: 32mm Keihin carbs in A14?? would it work? ddgonzal 2009/2/12 4:43
                           Re: 32mm Keihin carbs in A14?? would it work? datto1000wagon 2009/2/12 4:51
                         Re: 32mm Keihin carbs in A14?? would it work? datto12qld 2009/2/12 5:02
                           Re: 32mm Keihin carbs in A14?? would it work? 1200GXman 2009/2/12 6:38
                             Re: 32mm Keihin carbs in A14?? would it work? datto12qld 2009/2/12 8:05
                               Re: 32mm Keihin carbs in A14?? would it work? cheater_5 2009/2/12 8:42
                               Re: 32mm Keihin carbs in A14?? would it work? Bandit_blues 2009/2/12 10:49
                                 Re: 32mm Keihin carbs in A14?? would it work? datto12qld 2009/2/13 1:50
                                   Re: 32mm Keihin carbs in A14?? would it work? Bandit_blues 2009/2/13 9:37
                                     Re: 32mm Keihin carbs in A14?? would it work? 1200GXman 2009/2/13 11:25
                                       Re: 32mm Keihin carbs in A14?? would it work? Bandit_blues 2009/2/13 11:40
                                         Re: 32mm Keihin carbs in A14?? would it work? 1200GXman 2009/2/13 12:35
                                           Re: 32mm Keihin carbs in A14?? would it work? Bandit_blues 2009/2/13 13:00
