Need help with a 5 speed transmission
Can anyone help me out with A Datsun 5-speed transmission from August 1979 to 1982 Datsun 210. This can be from a coupe, sedan or wagon.
The input and output shafts should be 20mm (about 25/32") diameter and 18 spline.
The serial number on top of the bellhousing should begin with the letter "F" (FL, FA, FX etc. OK). The number "60" is cast into the right side of the main case. The model number for the transmission, FS5W60A, is sometimes found on the Serial Number plate on the firewall. This is not found on the transmission.
I also need to get the gearshift lever, throwout bearing carrier and clutch release fork.
Any help would be appreciatted
Posted on: 2009/3/8 2:15
Subject Poster Date
     Need help with a 5 speed transmission joep 2009/3/8 2:15
       Re: Need help with a 5 speed transmission tommo73 2009/3/8 2:46
         Re: Need help with a 5 speed transmission ddgonzal 2009/3/8 3:04
           Re: Need help with a 5 speed transmission clyons8 2009/3/8 3:39
             Re: Need help with a 5 speed transmission Dundee1000 2009/3/8 6:31
