Re: where should my Ammeter go ?
From Adelaide
Howdy,
if you are talking about mounting an ammeter in your dash to keep an eye on the charging system it needs to go in series with all of the cars electrical load except for the starter motor.
This can get quite messy as the ammeter can have upto 80 amps flowing through it and the cabelling needs to be large enough to cope.
for example: average car,
headlights 100 watts each
tail lights 15 watts each
brake lights 21 watts each
ignition (no injection or electronics) 50 watts
windscreen wipers, demisters, heater fan upto 200 watts.
so total watts used = 522 watts
Amps = watts / volts
522 / 12 = 43.5 amps
this is before you have added that "sick" CD player and amp (coupe of hundred more watts) and driving lights (200 more watts)
now we equal 922 watts =76 amps
Your best and safest bet is to use a volt meter instead. it is wired from any switched positive to ground and does not carry any load.
if the voltage is over 12 volts (13.8 is perfect) the battery is charging and if it is below 12 volts it is being discharged and will go flat sooner or later.
hope this helps.
Cheers,
Geoff
Posted on: 2009/3/23 12:11
Go Fast,
Or Go Home.
Subject Poster Date
     where should my Ammeter go ? Sumith 2009/3/23 6:52
       Re: where should my Ammeter go ? tonkatuff1512 2009/3/23 11:21
         Re: where should my Ammeter go ? SaCoupe73 2009/3/23 12:11
           Re: where should my Ammeter go ? ddgonzal 2009/3/23 20:15
             Re: where should my Ammeter go ? Sumith 2009/3/24 5:26
               Re: where should my Ammeter go ? 1200rallycar 2009/3/24 6:54
