Re: Stabilizer bar
From Ballarat Victoria
If you need to make a stablizer bar a bit wider to match longer LCA`s You can heat the front bends with gas torch until only very dull red and bend them out to suit the greater width requirement. while the bend is still very hot dip it into a tub of oil(used sump oil is fine) to re temper the bar.
I have done this several times on front bars for improved production racing and had no problems. (The cars are front runners and have had the bars on for years)
Simon.
EDIT. Hint: Mark out with chalk on your shed foor the shape you need the bar to be and use this as your template when bending.
Posted on: 2009/4/2 0:43
VIC DYNO HIRE
Subject Poster Date
     Stabilizer bar hatari 2009/3/30 22:10
       Re: Stabilizer bar LittleFireyOne 2009/3/31 0:30
         Re: Stabilizer bar ddgonzal 2009/3/31 0:58
       Re: Stabilizer bar PIGDOG 2009/3/31 1:38
         Re: Stabilizer bar sssute 2009/3/31 2:59
       Re: Stabilizer bar hatari 2009/3/31 12:40
         Re: Stabilizer bar dattodude 2009/3/31 21:33
           Re: Stabilizer bar BEN510 2009/4/1 0:01
             Re: Stabilizer bar sikyne 2009/4/2 0:43
       Re: Stabilizer bar old_school 2009/3/31 12:53
       Re: Stabilizer bar hatari 2009/3/31 21:29
       Re: Stabilizer bar wetdriftwarrior 2009/4/1 10:00
       Re: Stabilizer bar sunny_coupe110 2009/4/1 10:48
