Re: Supercharger & Carby
Take off the air cleaner and check the numbers stamped on the choke horn. post them here and I can tell you pretty much exactly what it is. Hopefully (I'm assuming it's a drawthrough) it's actually a 500cfm 2 barrel, as a supercharged 1.2 (let alone a 1.5) could really use the extra cfm.
If the choke horn has been machined off, flip it upside down, and measure the diameter of the throttle plates, and the carb size and model can be determined by that.
Hopefully it isn't a 320 holley, as they were made basically starting with a 350, but designed to run leaner (and they end up flowing 30cfm less as a result) with more sensitive boosters - they are basically an emissions friendly carb, and less performance oriented. The idle circuitry is also different, and the idle mixture (from memory) is adjusted the opposite way (i.e. the way the idle screws are turned to richen a 350 will lean a 320).
Posted on: 2009/5/20 17:32
John McKenzie
Subject Poster Date
     Supercharger & Carby tongy 2009/5/20 7:43
       Re: Supercharger & Carby Datsun1000 2009/5/20 8:38
       Re: Supercharger & Carby revhead001 2009/5/20 8:43
         Re: Supercharger & Carby steveo 2009/5/20 11:14
       Re: Supercharger & Carby jmac 2009/5/20 17:32
         Re: Supercharger & Carby tongy 2009/5/20 22:52
       Re: Supercharger & Carby tongy 2009/5/22 3:24
         Re: Supercharger & Carby steveo 2009/5/22 4:16
           Re: Supercharger & Carby tongy 2009/5/22 4:35
             Re: Supercharger & Carby steveo 2009/5/22 4:48
       Re: Supercharger & Carby clyons8 2009/5/22 6:38
       Re: Supercharger & Carby jmac 2009/5/22 7:18
       Re: Supercharger & Carby A14force 2009/5/22 10:31
       Re: Supercharger & Carby jmac 2009/5/24 10:41
