It went 'BANG' & then stopped
From sydney australia
Took the (Silver) Sunny coupe (I'm alliterate)to Wakefield yesterday & had a mixed day.In the end we suffered from old tyres (took 1 1/2 laps to warmup), a serious fuel leak (brake fitting sliced a fuel line) then the gearbox went bang & no more drive. Other than this we spun wheels,locked up brakes & slid the tail round. All this with only about 90 HP from a stock L18 with webers & extractors. The shift points are 5500 rpm 3rd to 4th,& 5000 rpm 4th to 5th,except at the Dogleg at Oran Park where we pull 5th at 4000 rpm because we would be changing in the middle of the corner. We'll probably get an R30 box for it, & definitely a bigger cam (Factory 74 degree grind). We're due back at Wakefield on July 5th, so I better get on with it.
Posted on: 2009/6/8 2:31
Subject Poster Date
     It went 'BANG' & then stopped b310gx 2009/6/8 2:31
       Re: It went 'BANG' & then stopped Mildman 2009/6/8 5:46
         Re: It went 'BANG' & then stopped b310gx 2009/6/8 23:14
       Re: It went 'BANG' & then stopped b310gx 2009/7/27 2:24
