Re: s13 adj camber tops
From Townsville, Qld
You might need to get a spacer machined up to fit inside the eylet bearing and take the load of the top spring hat and reduce play of the shock tube, but looking at that it appears that it may not be needed.
Posted on: 2009/6/12 9:47
Subject Poster Date
     s13 adj camber tops SomeDAT 2009/6/12 9:25
       Re: s13 adj camber tops LittleFireyOne 2009/6/12 9:47
       Re: s13 adj camber tops Anonymous 2009/6/14 13:10
         Re: s13 adj camber tops broccoli 2009/6/15 1:19
           Re: s13 adj camber tops SomeDAT 2009/6/16 13:21
             Re: s13 adj camber tops PIGDOG 2009/6/16 13:35
       Re: s13 adj camber tops SomeDAT 2009/6/16 13:52
       Re: s13 adj camber tops Anonymous 2009/6/17 0:15
