Re: Adjustable Camber / Castor Plates
From Cape Town, South Africa
Yesterday assembled it with a M12 HT bolt, worked great, will one day when it is in use see if it holds up, otherwise the next step will be to get a rose joint with a bigger diameter, even if this means re tapping thread on the shock.
Castor is adjusted by moving the rose joint from left to right by turning a nut or two on the bolt.
Posted on: 2009/6/23 10:15
Project Build: http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=45104&forum=9
Don't find a problem, find a solution!!!!
www.race-tech.co.za
Subject Poster Date
     Adjustable Camber / Castor Plates racetech 2009/6/22 9:56
       Re: Adjustable Camber / Castor Plates aidaniel 2009/6/22 10:00
       Re: Adjustable Camber / Castor Plates racetech 2009/6/22 10:02
       Re: Adjustable Camber / Castor Plates aidaniel 2009/6/22 10:13
         Re: Adjustable Camber / Castor Plates LittleFireyOne 2009/6/22 10:59
           Re: Adjustable Camber / Castor Plates LittleFireyOne 2009/6/22 13:10
       Re: Adjustable Camber / Castor Plates racetech 2009/6/22 11:24
         Re: Adjustable Camber / Castor Plates ROConnor 2009/6/22 11:32
       Re: Adjustable Camber / Castor Plates racetech 2009/6/22 12:00
       Re: Adjustable Camber / Castor Plates Fandatstick 2009/6/22 12:20
       Re: Adjustable Camber / Castor Plates racetech 2009/6/22 12:52
       Re: Adjustable Camber / Castor Plates racetech 2009/6/22 13:30
         Re: Adjustable Camber / Castor Plates WhiteSedan 2009/6/22 14:32
       Re: Adjustable Camber / Castor Plates Datsfullysik 2009/6/23 2:24
       Re: Adjustable Camber / Castor Plates wolki101 2009/6/23 7:09
       Re: Adjustable Camber / Castor Plates racetech 2009/6/23 10:15
       Re: Adjustable Camber / Castor Plates aidaniel 2009/6/23 10:29
       Re: Adjustable Camber / Castor Plates racetech 2009/6/23 11:24
       Re: Adjustable Camber / Castor Plates aidaniel 2009/6/23 12:03
       Re: Adjustable Camber / Castor Plates levey 2009/6/23 12:47
         Re: Adjustable Camber / Castor Plates Daveman 2009/6/23 13:22
       Re: Adjustable Camber / Castor Plates 1200GXman 2009/6/23 13:40
       Re: Adjustable Camber / Castor Plates aidaniel 2009/6/23 14:04
       Re: Adjustable Camber / Castor Plates racetech 2009/6/23 14:27
         Re: Adjustable Camber / Castor Plates PIGDOG 2009/6/23 14:36
       Re: Adjustable Camber / Castor Plates superbin 2009/6/23 17:08
       Re: Adjustable Camber / Castor Plates LOWTECH 2009/6/28 3:55
