Re: Can i use any ignition coil?
How do you mean? It doesn't work?
What was the compression test readings? Exactly the same or 10 psi different?
Posted on: 2009/6/30 7:05
Subject Poster Date
     Can i use any ignition coil? Need help with ignition trouble... Ronny_CTS 2009/6/29 20:03
       Re: Can i use any ignition coil? ddgonzal 2009/6/29 22:07
       Re: Can i use any ignition coil? Ronny_CTS 2009/6/29 22:59
         Re: Can i use any ignition coil? ddgonzal 2009/6/30 7:05
       Re: Can i use any ignition coil? Need help with ignition trouble... Ronny_CTS 2009/6/30 10:41
